MetroX FullField infinite frame duplication
Hello,
I’m trying to scan an object using full field mode, but when I move the scanner to scan the part, the scanner starts duplicating the scanned images to infinity.
Do I need to calibrate the scanner again or what is the solutions?
Can’t tell from the screenshot, but this is feature mode, right? I think it’s just getting confused trying to track it. The system can only see a small part of the image at a time, and it has to be able to figure out what it’s looking at. Try adding some random items around it. I’ve used wadded up paper, bits of blue-tak, etc.. It helps the software figure out where it is.
Or put it on the turntable and use marker mode. Not every object will scan well in feature mode. I suspect calibration is fine. You just need to adjust your setup a little. Maybe show us what you are trying to scan, someone might have something similar they have done and can recommend settings.
This means it lose tracking due to not enough features on the object . Follow @ttabbal tips it will help you out
