Hi all,
I’d like to extend the distance between the scanner and my PC and I find the wifi option to be a bit unstable vs the wired. There is plenty of length in the overall cable unit from mains plug to scanner, but I need the usb cable going to the computer to be longer.
Any reason I can’t use a USB C extension lead on this? Or if signal is an issue, a hub purely for the scanner?
