Yes you can use it , the mobile cable is just a power cable, no data flows through it . It is only used for powering and connection via WiFi and I use one too with battery pack in my pocket lol
What Mike is asking is simple power cable extension to use it with WiFi and power bank
You can use any USB C cable for that purpose.
But in your case you are replacing the data cable and I can’t guarantee you that it will works since MeyroY Pro has its own unique cables that support both power and data
Unless it is just a power cable to support the WiFi … But make sure you use the proper power source to power the MetroY Pro , you can find the numbers on the AC adapter and the battery pack .
Yes, that’s a good point. I bought this male cable for Metrox. A local Telegram group suggested this solution. Everything works fine for this person. As far as I understand, the cables for Metrox and MetroY are identical. But I’ll definitely check the polarity and voltage with a multimeter.
The cables for both MetroY and MetroY Pro are identical , MetroY Pro just using slightly more power but not higher voltage as both AC adapters are the same .
Remember not to plug it in the wrong power source, if it get damage the warranty will be voided especially when aftermarket cables was used while on the warranty.
No problem Mike !
For WiFi it is a perfect solution ! The low capacity of the original power bank made me using the cable and my 50.000 Am power bank the day I got the scanner.
