I have been wanting to get in to the world of 3D scanning for sometime.
Then the POP 2 was released on Kickstarter which finally made 3d scanning approachable.
I backed the project in early December 2021.
April 13 2022 the POP 2 Premium Package arrived at my home.
Today I had time to get started and I set up everything up on my desk.
Here are some of my first scans of an ammonite fossil.
The next scans were of a vintage Toyota badge.
It seems to really use up system resources but made it through.
Next was a handmade mug.
This link is to a navigable model of the mug.
So far I am having a lot of fun with it. I don’t have any real workflow figured out yet and I am still unfamiliar with the software but it works!.
Revopoint thanks for making this scanner.
I’ll post more as it happens.
Looking good ! For your first time scanning you did a great job
Try with the setting lower in the depth view (bottom window) a dark to light grey is good, when its white it’s over exposed a bit
Thanks you your try-outs.
Wish you enjoying the backed POP2.
I am still waiting for it.
@TinWhisperer great results ! but as @Johnathan mentioned your gain setting ( Depth Camera) is much too high , you will easy lose the track at that setting . Usually 1-2 maximum, unless you have a darker surface . So next time you run into trouble , set the gain down !
keep up with the great work !
Thanks @Johnathan @Johnathan @jeremias_29 I will adjust that setting and keep trying.
Session 2
Scanned an old tape measure.
Some of the shiny bit did not show up but that is to be expected I gather
Odd looking texture file?
And here is a interactive model
Received my CD key last night so maybe later today I’ll start to learn and work with Revo Studio.
How did you get the Toyota badge to scan that clean?
I used marker mode on the turntable.
I did quite a few revolutions I can’t remember how many.
I didn’t have a revopoint studio CD key at the time so I used mesh mixer and fusion 360.
the results of the 3rd and 4th session.
a small seashell
and a toy elephant
Fusion (this link seems to stall out.)
The post processing is something I’ll need to spend al ot more time with.
It is quite an art and I have so much to learn.
seems like this link the elephant model is working great now! check it out for yourself.
Yes it is working !
you forgot to close the holes
lol yeah,
. I have no real post processing skills yet.
I took that scan straight from revoscan and loaded them into Fusion 360.
I rotate it to be square with origin.
I use this one tool on it
and posted it here.
Still not sure of the work flow or software.
I have used fusion 360 a lot but for sheet metal assemblies and CNC plasma CAM.
so my mesh skills are zero so far. It is a whole new world.
You need to remesh the scan for smaller size other way would be too big for share , I am doing organic modeling for the last 24 years , my specialty . Scanning is one thing and proper processing another, then you have organic and hard edge modeling 2 different process and approach .
I am preparing right now another tutorial , for merging objects etc…
I kept working on learning this process some more this weekend.
Starting scaning a Homelite gas powered circular saw .
Thought is was a good way to start scanning larger more complex items that have to be pieces together afterward.
still struggling with getting the bottom to align but happy with the steady progress.
I also scan a Schleich toy sheep
it stand 2.5" tall and 3" long
Sometimes it just don’t want to work for some reason even with the manual points , but finishing today the Cloud Compare tutorial for merging the objects , it works superior to Revo Scan
good job scanning your new stuff , looks very good .
Thank you.
I did try Cloud compared too ( keep in mind I know nothing about Cloud compare) but for some reason it was still having trouble aligning that same bottom panel? I even tried to rescan the bottom a couple different ways and it just does not want to attach that bottom panel.
I think I’ll order some 3D scanning spray and then clean up the circular saw quite a bit.
I can see that I am going to have to set up a little bit of a studio for 3D capture in my office.
Area and item preparation seems to be one of the most important aspects of this game.
In Cloud compare it like to have a lot of markers on any directions , then you can see the errors you made while placing the markers . Make sure your scans’ holes are not closed , sometimes Revo Scan close the holes even if I set OFF , so the most safe way is to work with the point cloud only with all the same pitch point settings for best results .
I had some time to scan another piece, a bookend.
Very nice scan you got here !
Well thank you very much but I owe quite a bit of my success to reading your contributions on this forum.
