That might help you sort it out. Sounds like some systems don’t like powering the Inspire directly. Perhaps try with a power bank or charger brick.
Let it boot, and it should be visible as a WiFi AP. Connect the PC to it and see if it works. If so, you might just need a cable that splits power and data. It could also be a hardware issue with the scanner or possibly the cable.
ok so i guess i installed the wrong software… metro? that was not working… but i found the other… no idea what the difference is but i’m in business now.
