Hello everyone, Revo Assistant 1.3.0 for mobiles is now online.
Download it from your phone’s app store by searching for Revo Assistant.
Update Notes:
- Adds an advanced mode for greater control over the Dual-axis Turntable.
This new feature allows users to create and save customized presets for the Dual-axis Turntable to control the rotation direction, angle, speed, and number of rotation turns.
Basic Operations:
(1) Create a New Template:
Tap Advanced, then tap the “Add New Preset” button to set the preset’s name.
(2) Parameter Settings:
Set the required rotation direction, angle, speed, and number of rotations.
(3) Template/Preset Selection:
Choose either a custom preset or tap on the “Defaults” in the top-right corner to select a template.
(4) Template Usage:
Tap “Start” or “Pause” to start or pause the process. While paused, you can modify the parameters of custom presets. Tap “Reset” to return the Dual-axis Turntable to a horizontal position.
