[iOS&Android] Revo Scan 6 V6.0.4 is Available now
Hi guys, Revo Scan 6 V6.0.4 is available now. Download it here: 3D Scanner Software Downloads for Windows, macOS, iOS and Android | Revopoint
What’s New:
1. Added support for RANGE 3 and RANGE 3 Pro 3D scanners.
2. Introduced a new Multi-line Laser Scan Mode for RANGE 3 Pro, supporting marker mode.
3. Added point distance settings (applicable to Multi-line Laser Scan Mode).
4. Added a “Large Object Scan” button (disabled by default). When enabled, the target point distance automatically adjusts to 2 mm to meet the requirements for scanning large-sized objects.
5. Added global marker fusion quality display and a marker quality color-coded map.
6. Implemented real-time memory monitoring for Laser Line Scan Mode. Scanning will automatically pause when RAM reaches its limit, allowing users to manually complete the scan and proceed to the post-processing workflow.
7. Optimized the visual design of the exposure slider, making before-and-after adjustment comparisons more intuitive.
8. Updated the mobile meshing module to align with the meshing features of Revo Scan 6 on PC.
9. Updated post-processing point cloud fusion to align with the point cloud fusion capabilities of Revo Scan 6 on PC.
10. Improved cross-version compatibility for scan projects, allowing mobile scan projects to be exported or shared to Revo Scan 5 on PC.
