Revoscan 6.4.2 has been released
Hi all,
The revoscan 6.4.2 has been released and is currently being tested, but markerless laser scanning and a basic version of Revo Measure are available.
Hmmm, sorry, the Markerless laser scanning doesn’t work with my POP4, eveything else does.
Hi, here you can see my test, for my pop 4 non problem. i’ve just realise this test in low resolution but result is very good
I tried re-installing the software and tested it again,
The scanning in markerless laser mode is very slow, but I did get a result.
I also noticed that when I clicked on “Scanner Information” it tells me that the scanner isn’t connected, even though I can see it is in the bottom left of the screen.
Great news, I recalibrated my POP4 and now have much better performance and results !
Ok perfect
it work fine with models with much details ans colors, but it’s more difficult with others object, i’ve try with an black headrest… There are surely some adjustments to be made or improvements to come
Hi Mike ,
You should always recalibrate after installing new firmware or new software with new features , but good you find it out by yourself .
Still no Metro integration ?
Hi do you know if a pop 4 firmware will be released ?
Hi @sbeef
The new firmware was just released not long time ago allowing laser mode to scan without markers and use color for tracking instead.
I don’t have any info about when the next one will be released and what will be added or changed.
Hi, ok the this new firmware goes with the new revoscan release 6.4.2 ?
Yes it does , why ? Do you have issues ? For any technical issues between the software and your scanner please contact customer@revopoint3d.com for technical assistance. Include the last firmware info as well .
non i havent issues, I hope the new firmware will further improve this new mode
That for sure , the team adding always new features with the time and improvement.
Hi, Do you know if the new version of Revoscan, which will bring all the scanners together, is coming out any time soon?
