[Windows] Revo Scan 6 V6.4.1 is now available
Hi, Revo Scan 6 V6.4.1 is now available on our official website.
Updates:
1. Optimized display quality for laser line scanning;
2. Added a toggle to remove isolated points during point cloud fusion;
3. Added support for the PLY point cloud format when importing/exporting global markers;
4. Added a scan quality indicator for global markers in Global Marker scanning mode;
5. Added Line Laser scanning support to Color Tracking mode (Note: Requires a PC with a dedicated graphics card and POP 4 firmware version v5.3.99 or later);
6. Added a scan quality map for VCSEL mode;
7. Models created by laser line scanning now support texture mapping using secondary photos taken with a smartphone or DSLR;
8. Raw point clouds can now be edited; additionally, in laser line scanning mode, projects containing markers allow for marker editing within the raw point cloud view;
9. Merged Line Laser scan models now support 3DGS training;
10. Merged models support supplementary 3DGS training using images captured by a smartphone or DSLR;
11. Fixed various known issues.
Note: To perform laser line scanning with color tracking mode using the POP 4, the scanner must be updated to firmware version v5.3.99 or later, and the PC must be equipped with a dedicated graphics card.
Download it at: 3D Scanner Software Downloads for Windows, macOS, iOS and Android | Revopoint
Is there an eta on the Pop4 Firmware?
I was waiting for that feature 4 years :laughing:
The firmware will be released slowly in the period of the next 2 weeks
I hope this function will be added to Revo Metro as well.
They keep saying Laser Line scanning for both photo texture and 3GS new features.
Was that supposed to be just laser scanning (both modes) or single line laser scanning?
Also I hope you have a tutorial coming for these features as I expect this to not be a simple point and shoot workflow :confused:
Hi @antsht
Revo Scan 6 is the new blue print for the future new Master software that will works with all scanners so hopefully other scanners will be able to use the features as well.
Hi Filip
Merged models support supplementary 3DGS training using images captured by a smartphone or DSLR; So this means regardless what mode you are using .
Yes tutorials will be available .
Ok
Texture from photos - it’s a little touch and go. When it works, it’s amazing. But on more then one occasion I got the error that the content of photos differs too much from the scanned data even though the photographs were made in the same place, same lighting and same angles as scanning and texture capture process.
Sometimes redoing the scan and using the same folder with photographs is enough to make it work.
Gaussian from photos - couldn’t get this to work, seems it needs a lot of photos to work, much more than I’m willing to take for a solution that is NOT photogrammetry :wink:
Merged objects
  • if partial scans had texture capture - the color data transfers to merge object - finally :slight_smile:
  • if partial scans had texture made with additional photos - these also transfer
Gaussian splatting doesn’t work for me - it seems to use color data only from a single partial scan.
Say I have three scans, each with color data, I can make a Gaussian splat in each one of them.
Now I merge the 3 scans together.
If I try to make the Gaussian spat now on the merged project, it looks like the algorithm picks one of the three partial scans and uses its color data exclusively for the Gaussian splat. If a part of an object was not visible in that particular partial scan - the gaussian splat will not contain that part - even though the merged mesh contains it and even creates a texture for it.
All in all Gaussian splats are still a work in progress, but the texturing is fast closing to being perfect.
Can we just get an explanation how are additional photos mapped onto the geometry. They are probably compared with photos taken by the scanner, yes? That would require the photos to be similar to those taken by the scanner, and if the scanner RGB camera struggled in the lighting conditions, good quality photos would register as being too different from the texture data? That is my guess so far.
Just did my first laser scan without markers! Of course fps is lower but worked great, so nice to have another option, great work!
Hi Filip ,
Thank you for your feedback , I will review all the parts your mention
Great, when will we get GPU acceleration (or at least reasonable CPU usage) during point cloud processing/meshing? I’ve been on “1 minute remaining” for eight minutes and it’s 10% done. This makes the scanner nearly unusable unless I have other work to do in the meantime. It never goes above 5% CPU usage and seems to only touch 4 out of 24 available threads, and barely even uses those 4 threads.
Specs:
Ryzen 9 9900X3D
64GB DDR5
RTX 5080
Hi @johna32
The slow processing has nothing to do with CPU power but rather the amount of RAM it uses while processing , having it any faster will cost you more RAM than your system can offer.
You want faster processing ? Change the fusing point , that is all right now you can do.
Laser processing sadly take long time because of the technology and it’s small laser point frames .
The Dev. Team is working on future improvements regarding speed etc, but it is not an easy task and definitely nothing for GPU processing unless your GPU offers 64 VRAM and system double of that .
Does this mean that 6.4.1 is intended to merge the Pop and Metro series?
In the future there will be just one software , but I don’t have more details about when exactly , maybe already Revo Scan 7 :wink:
I know the team is working on it on the side.
Hi,
I’m fusing this at 0.10, with a 99 min estimate.
But I can see Revoscan 6 is not using all of the available system resources, to speed up that fusing time.
I have plenty of system memory available, 58.4GB free of 128GB, and 18.8 GB free of VRAM, with maybe 5% GPU usage:
Looking at the Revoscan process it’s not exceeding 11GB of used system memory.
I ran the performance check, tool in Revoscan for it to detect my hardware, and it enabled GPU Acceleration, and says: Your PC can run POP 4 optimally.
Are there advanced settings that can be enabled to get it to use more of the VRAM / RAM / GPU to speed up this processing time?
This would make sense if I didn’t have 64GB of RAM, 43GB available with Revo Scan only using 8-10GB max. GPU has 16GB dedicated VRAM and Revo Scan isn’t using any at all.
This is CPU based software and it don’t use GPU or GPU VRAM.
And right now there is nothing you can do to speed it up.
Intel CPU are doing the work much faster .
If you want more info please drop an email to customer@revopoint3d.com for technical assistance and feedback .
Hi @grimmx
What are you scanning that it use so much RAM and processing time?
I never had to wait longer than 30 min on a huge scan with lots of fine details
Can you share the software screenshot with the fusing details of the scan ? I want to see the numbers
