I have a Revopoint Pop 2, but this defect always appears on part of the piece when I fuse it. How can I solve this? Thank you in advance!
This “defect” is overlapping points that were not cleaned out after merging , just to run lose points and overlapped points function after merging, try to slide the sliders down and up to clean it out and after that mesh it .
It should resolve the artifacts issue .
The problem is that before generating the mesh this defect already appears and there is a lot of dust, because I have already passed it and it is completely white, I have scanned it about 6 times and the same problem happens before making the mesh
How do you post process your scan BEFORE you mesh the point cloud? Do you use “isolation” and " overlapping detection" like PUTV said to clean up the scan BEFORE you mesh it?
That what I tried to tell you … clean it up before meshing
Anyway can you zip up the project and upload link to check it out ?
This happens to all my flat pieces, I’m using one-click editing and it always comes out like this, can I send you the file so you can help me? Thanks!
stl and ply extensions are not accepted here
You need to zip up the project with the scans upload to a Google or other free hosting and upload the link to it , you can do via PM as well. I need all the 2 pieces before merge as point cloud
