I want to add my scanned tops and other objects in unity. To be able to use in vrchat. Can someone please help me? Thanks
Hi @Revo_Girl
Check on YouTube , there are lots of resources regarding importing models to Unity , you don’t find it here .
Good luck ![]()
Hi, it can be done, but it involves several steps. PM Me for more info.Mike.
Forgot about you Mike ![]()
Thanks Mike. I really appreciate your help ![]()
If you’re looking for the cleanest import, go with .FBX. It tends to keep the scale and rotation a bit more consistent in Unity compared to .OBJ. Also, make sure your ‘Texture’ is exported as a separate file - you’ll need to create a new Material in Unity and drop that texture into the Albedo slot to get it looking right.
