Hole fill density
Hi all,
I’ve tried out the very latest software and I must say it continues to improve, so great job all round!
One thing that may be nice to see is when you do a mesh hole fill, where you can select the hole you want to fill, is that the filling mesh density equals that around it. The hole (in my case marker holes) and filled with some ludicrous amount of facets. It far from matches the surface around it. It may also prevent some bulging which I seem to be getting on the curved fill options.
Cheers
The curved option is for round organic models , if you want flat , use the plane mode .
After you are done with your mesh , please Simplify it using 1% , it will remesh the whole surface with a equal amount of triangles everywhere focusing mostly on details .
