Hello, I would like to fill holes and curved sections in a symmetric figure in a hard section to reach by the scanner using feature mode.
Following you can see the figure fused
You used plane mode for fixing organic shape … not good , plane mode is for flat surface .
However since you missed part like that I don’t think fixing holes will fix that , it is not a reconstruction of a missing parts , it is a hole closer function on a flat or round surface so don’t expect this to reconstruct your missing parts .
Scan it better or create reverse engineering model based on this scan as normally everyone would do .
Or edit the area manually with some sculpting brush in your 3D modeling software .
