I received my MINI and dual axis turn table, connected the MINI to my Win11 Core I7 16GB Ram Laptop, and started Revo Scan 4.1.1. It showed a message pointing that I need to upgrade the firmware to be able to use the dual axis turn table, so I started the firmware upgrade, but it was not successful. So, I came to this forum looking for a solution, and as was trying the fixes I found here from plug and unplug and retry to pressing the button 10 times after 30 seconds from boot when I get a steady blue indicator.
The MINI was working as I preformed a test scan while manually moving the object and it was very good.
The problem:
After many attempts to upgrade the firmware, the indicator got stuck on blue and 10 presses won’t work anymore, and windows is not detecting the device in device manager.
A little Hope:
Interestingly, I tried something that wasn’t mentioned anywhere where I searched on the internet.
When I powered up my MINI I held the button while the indicator is white, and the indicator became red! Then I released the button while it’s red and it turned green for a while then blue and then it’s stuck at blue again.
I hope I can make it work and I appreciate any help I can get.
If the led on the back is Blue after all the attempts, I guess only @Revopoint3D-Gena or @Revopoint3d-Selina can help you here , as you run out of all options available already .
I am not sure if they working this Saturday since they are on Beijing time ( right now 2:51 am Saturday )
If not they may be back at you on Monday with more support.
I have not had this problem, so I can only relate what I have read, but did you make the 10 button presses quick or long? I have read that it should be 10 quick presses.
