@PUTV - I didn`t actually purchase car for some time and was riding bike to work for at least 8 years..
Just saying..
And if I may follow your line of thoughts, you wish to tell me that better to order Ferrari SX90 or Bugatti Chiron for Pizza delivering because is faster.. Or MacLaren F1 for an UBER.. ![]()
Jokes aside, Wifi is quite good option! No doubt! But as you saw from my initial video and post it did not worked also when I have my issue, which I’m not so sure I got rid of..
So I was not able to use Fullfield light neither in Wifi neither in Wire mode..
Great option, but if i have tight budget and can afford used but in a great shape Metro X, don’t see how that options so far will force me to pay 50% more. Just thoughts again over the topic.
More capable FOV..
That is also great! Still, could you show some stats how many percent improvement and better results , speed will give over that one`s came FOV fitted in metro X?
Can it be same 30% as the price goes up..![]()
2 milion points vs 800k - Great improvement no doubt, same as 64 lines vs 30!
But to be honest I drop on video showing the actual frame rate what metro X claim in the software corner and what the field camera is capable and there was significant difference.
The author of the video pointed out that even with more points/sec on paper, the actual scan speed and allowed movement was lower than the competitor’s he was comparing with, and which was with lower point count per second anyway claimed in their advert..
Just saying.. Not tested personally with that Metro Y how actually real the data is. For the sake of argument, will accept is 100% real.
Before to be ridiculed, I still need to point that I already bought and OWN metro Y pro , which I pay for from my own pocket!
In some of the other topic’s posts, you have mentioned that you have over 30 years of experience using 3D scanning software. I honestly didn’t know that tech existed so far in the past, but I absolute agree with your opinion that now is just incredible to have such tools on that price for every one!
Well, also we have pocket computer called CellPhone which have probably more brain and calculating power than NASA’s computer when they put the man in space..
That’s the good thing of technology - goes forward, and get cheap!
Yes, 5.4.8 software indeed switching fast between laser modes compared to 5.3. You’re correct!
And yes, I agree that switching between Structured light and Laser mode requires some core switching process, perhaps some different kernel mode for using the GPU and etc.
If I understand right, the scanner itself have 2.0GHz ARM cpu inside. So that is not exactly on the slowest end. And the synchronization-self calibration between the stripes pattern and the camera refresh rate seems to happen in about 5sec.. The rest of the time is more to the computer GUI side and GPU control. Just speculating here, but can it be?
For those who actually saw my video in the previous post with the issue can see that the Fullfield mode was not switching at all. And that was mainly caused of leftover settings and files from Metro X’s software (probably, not quite sure..)
For me that is indicator that the switching mode progress is initiated in the computer side, so there can be some slower part in the software what actually generate that delay.
Here is another VIDEO that show how much RAM goes when make laser scan, Fullfield light been used, and how much CPU.
From that test I got the impression, some 96GB of ram will be much better and for really huge scan probably the SWAP/Virtual memory will kick in with that fast growing ram demand.
Then, in the other hand the VRAM stays constantly in the range of 1.5Gb.
That fact make me to think that even 4Gb GPU vRAM actually will do the job too. Unless of course the CUDA cores been used for that point triangulation calculation in an old card will not keep up with the data.
Also, there is something that I found and it repeat with every test.
My notebook have 3200x2000 screen resolution. For that reason I set it as 150% screen scale.
And because of that, I have to check the option for DPI control of that METRO.exe program’s properties so it fill the screen properly.
But, if initiate a project and I’m ready for scan job to start, then by clicking over the “square” icon (upper right corner) to resize the window and it just freeze!
Sure, after some seconds I can open the menu for the rotary table , or help but the central screen with camera and laser points just stay frozen..(Let it goo.. Let it go…)
Yep, the scanner is ready to send data and communicate with the program, but nothing moves in that zone of the UI. Minimize and close work as should..
So, can you check and confirm if that is the same case (or not) with you too..
