I am just surprised that you got so many frames ( maximum available ) because others complaining that Quadro cards give them very low speed in general , and the fact that Quadro card drivers was not ideal , however maybe the developing team changed something in the last build that I don’t know about .
Well I am going to use you as a reference from now on
The listed MetroY Pro minimum requirements are an 8GB RTX 3060. The RTX Quadro 8000 I intended to use has twice the theoretical compute performance and eight times the memory. It should at the very least function, anything with CUDA compute compatibility 7.5 or greater, should.
You replied earlier to another user with the following:
“you are correct , sadly Revo Metro use the graphic card features that Quadro cards was not design to do well including it’s driver, it just need a fast gaming card , and a simple $300 card my doing the job faster than your expensive quadro card”
You have yet to explain which specific function, CUDA or otherwise, that the gaming drivers or cards provide that the professional drivers do not. Please explain in technical detail which function is missing.
I am asking you this because I know for a fact that there is not a single function or capability that an nVidia RTX gaming card supports that an nVidia professional card of the same architecture does not - in many cases they are the same piece of silicon. Professional cards do run at more conservative clock speeds and have error correcting memory, so Revopoint software may not run as fast on professional cards, but there should be nothing that stops it from functioning.
I would understand if you were making claims that CUDA compute capability 8.6 found on 30 series or newer is required, but that’s not the case - Many professional cards support CUDA 8.6 and all of the 20-series card and 1660ti which work ‘unofficially’ also only support 7.5, so it’s not a CUDA compatibility issue.
Without an explaination as to this mystery function that only gaming cards can offer, that means there’s clearly a non-technical reason why Revopoint is choosing not to support professional cards. I can speculate as to why, but the decision not to support professional cards is clearly not one defined by the technical capabilities of a professional nVidia GPU vs the capabilities of an nVidia Gaming GPU. As a customer who has spent a significant sum of money on a product from Revopoint, I’d like to know why this choice was made.
You don’t need to get higher than 4080 , 4060 will already reach the maximum frame rate .
The recommended graphic card is always the optimal graphic card, check the specification under your scanner .
Former Metro X user - I’ve just received my Y Pro.
I have also been told that there is no support for the 50- series after I thought I read that it is supported.
I have it as an eGPU but when I tried scanning, I encountered an error, stating that I needed more markers. Ironically, it scans better with the A1000 internal GPU - the only issue is crashing without warning.
Since being told that the 5070 isn’t supported, I have just bought a 4060 because I’m desperate. Should that give me better results?
P.S. My laptop is a Zbook Fury G9 with 64GB of RAM and I’m on the latest Revo Scan version.
Revo Metro is so fast you will get as good speed when using CPU instead of GPU acceleration, I tested and CPU i9 14th Gen was actually faster.
It don’t scan with internal GPU as it can’t use any GPU without CUDA cores for scanning and set under sertings, it may just use only your CPU
I have it too and it works excellent without any issue .
If it ask for more markers , there are 2 issues, not enough markers per frame , the markers are not in unique pattern, they are much too close to each other .
And last thing , please recalibrate your scanner with the latest software , usually it fix the markers issues.
My apologies; the words they used is that drivers for the 5070 haven’t been optimised and that it’s best to disable GPU processing.
Scanning performance using the CPU is fine but the software crashes unexpectedly every time I use it, so I thought that utilising a better GPU might solve the problem.
So far I have been unable to get a good scan owing to the crashing problem using CPU only. My marker locations work find with CPU-only scanning.
Thank you for your time on this. I will see how I get on with the RTX 4060 when it arrives. I already know that Thunderbolt 4 is a bottleneck but I am hoping for better performance.
The crashing issues will be addressed in the middle of March with a new software update .
I hope your crashing issues refer to MetroY Pro , as MetroX users crashing issues are also confirmed already and not much related to the graphic card but the software itself.
Thank you for your feedback, I will report it as well, but it would be great if you can send a email to customer@revopoint3d.com and address the crashing issue while using CPU , they may ask you for the log files to confirm it , right now the team is working intensly on fixing this issue so any new logs would help them as well.
The CPU performance is amazing compared to where it once was but it is little overloaded and that may be the cause of the spontaneous crashing while scanning as I experienced it myself as well. Not always but too often.
let me know the speed of the frames per second and the scanner you using , maybe it is just a note and your GPU acceleration will works at full speed .
I have conversation today regarding your issue , if you provide me with the proper speed of the frames while using GPU acceleration, it could be very helpful .
I strongly believe that the message you getting under that Graphic card is just by mistake and the software just don’t recognize it correctly . If the GPU speed is correct then it will be the case .
The RTX 4050 should be 20-30% slower in GPU acceleration than the RTX 4060 so please give me the number and what scanner you used.
That are just perfect results , having faster graphic card than 4060 will not really make it any faster , the reason why I don’t plan to update any day soon , Optimal results are archived with 4060 .
I told you early , it is just overreacted warning and I already talk about it to the team , this kind of system checking are not really usable and only cause misunderstanding. Your card deliver 20-30% better performance compared to my 4060 and I don’t have any warning message, it just don’t recognize it correctly in the system what is 100% bug but absolutely do not affect the performance, as long you are running the best graphic driver, nothing else can affect the results in this case.
Thank you for your report I will use it in the case to dismiss the warning under the settings in the future.
Hi, i’m looking for an powerfull 3d scanner. The Metro X or Y seems to be a good choice.
Question for me is wether i’m able to use the full power (high scan-fps i think) of this scanners with my desktop system :
Or is it necessary to buy an nVidia RTX GPU, which would be a big additional invest.
Requirements seem to show the need of a nVidia RTX GPU
Do i have to have connection to my desktop while scanning ?
Or is the CPU/GPU power only necessary for post-processing ?
What is the difference between Metro X and Metro Y ?
