Getting better detail
hi, as a test i tried scanning in a action man figure. i used scanning spray on the darker parts and placed the figure on the turn table.
during the scan it looked like the scanner a metrox was picking out the detail. however after i pressed the complete scan of over 10,000 frames the figure just turned into a sort of blue blob, gone was the detail. is there a way to keep the detail at all. the scanner was set to field, is this a problem of mine or is it a software issue, or computer issue.
thanks
Hi @Terry1956
Nie you need to click FUSE tab and create a point cloud from it , after that clean lose points and overlapped point before meshing it into model .
