Hello,
I am new to the forum and I have a question or problem, I have installed version 3.0.6.1013 on Windows 10 and the gain setting is gone. Is this normal? Thanks
Hi @osado ,
Yes, it is normal. We revised the design to avoid users’ wrong adjustments.
Cassie
“users’ wrong adjustments”, huh? You don’t seem to have much trust in the users. Actually, I’m still waiting - and I know others do, too - for a statement about the crypted config-files and whether there are plans of opening them in an “advanced users” mode or something.
So am I correct in thinking that we can no longer adjust gain to help scan more reflective areas of parts like machined surfaces?
Hi @Eldkatten @Adam ,
Since different users have different requirements and needs, we revise the setting to ensure that the common user can quickly get a better result.
If you think the gain is very important, I will discuss it with our developer team and see if there’s a better way.
Cassie
Hi @Revopoint-Cassie, @Eldkatten, @Adam I understand that the solution could be, allow the two options, one for beginners and the other for more experienced users
