Fusion removes some parts that are large but detached
This is the fused result of a Nintendo Switch 2 controller.
This is raw, why the entire joystick (thumbstick) is removed after fusion? It should never do that and this isolation should be done by user or post processing.
Werid enough that fusion never removes the actual noise but removes disconnected parts… I know that the thumbstick is sheding the connection part from the laser beams, but still, why a part this large got removed anyway…?
Yes, I remarked on this a while ago. You can sometimes raise the point distance setting a few notches to get some of the disconnected parts back.
They really need to get this fixed :frowning:
I hope you did not used Quick Edit option and go for manual fusing.
I would recommend you scan more frames with laser mode to get better surface.
The issues with the removed parts started when the software removed the markers, it recognize badly some parts on the object thinking it were markers if the objects has only partial scan data in that areas of round details .
Fusing should not remove anything automatic the user don’t want .. should be choice for the after fusing edit.
So totally agree
But to avoid issues for now , collect more data around the elements .
I am using manual fusing, and I tried various fusing distance. A large distance works (e.g., 0.5mm). But the quality is bad then.
There is no way to scan that area to make it connected, it’s a mushroom shaped object, and it’s small so you can not really reach into there.
I didn’t enable remove markers.
It should not remove it normally , so definitely the marker removal settings are somehow automatic , since the holes are closed as well after fusing .. need to recheck and report to the team
I’ll upload the scan project to somewhere and then link it back later, hopefully would be helpful to diagnose the bug
Hi I’ve uploaded the project, you can try to fuse from any of the scans using 0.2mm or 0.3mm distance, I think both would remove the thumbstick.
(Yes it’s quite noisy I know, there was a reflective background)
Scan the stick area more.
It is not enough dats on the stick and is getting filter out.
Ive scanned maby controllers before and this happen when there is not enough dats collected for the thumb stick
This is a long known problem in the software, maybe you can mention it again here to bump up
No. It has enough data on the thumb area, but it doesn’t have enough data on the connecting stick itself. The JoyCon 2 has a very hard to scan, well hidden connection area/connection stick. There’s no way for the scanner to reach into that.
There is absolutely enough data for the stick itself, but it still gets removed. And I think the reason is that the laser cannot reach the connecting stick behind it. However, it still cannot explain why this part specifically gets removed, while many other disconnected areas didn’t.
@Revopoint-Gloria @Revopoint-Cassie
Also, if I change the fusion distance (from 0.2mm to 0.4mm), then it magically gets connected again sometimes. 0.4mm is definitely not gonna change the connection situation of the RAW data.
Yeah I think it’s quite annoying to say at least.
It is recognized as a floating marker that why it is removed. Thanks to it’s round shape and not fully connected .
There was never issues before with scanning lose parts , but since the automatic removing marker function under fusion that everyone wanted so badly . And there is not surprise why . Neither is a bug .. just simple algorithms that should be not performing automatic unless selected.
I was surprised the other buttons was intact.
