The markers are not a volume , you need to test it with a proper volume and not 2D flat markers .
I would not recommend using the turntable for single shot mode unless it use the android app where you can set up the timer
You can download it here if you own the dual axis turntable, it works great .
And if future please use proper volume according to your scanner specifications to test out stuff .
