Exported data is raw only MIRACO
Hi,
I just updated Revoscan to 5.4.12 on both Macbook pro and win10 pro pc
the problem is when i finish scan i make all other steps at the miraco and then go to export to pc and transfare files
till here all things are okay
the issue is the mesh final work is not sended to pc
and when i open revoscan after that it makes me start fusing and all other steps from row data
please help …
device : miraco
Thanks
ikido
After you imported the projects to your computer , just open it and select the specific tab to be able to see the work you already did on MIRACO
If you fused and meshed on Miraco before importing , you should have the files in the project
Just select the meshed tab and you can export the model
Make sure your importing folder on your PC have permission to be accessible by Revo Scan 5 , writing and reading permission.
I would recommend you process your projects on Computer for faster and better quality .
