I think we can safely say, that since the Miraco is meant as a stand alone device, in many cases the only thing you actually would want to export from it is the final result (mesh or textured mesh). As far as I can see this is not possible currently.
When using a Mac, where Miraco can’t work as external drive according to the message when the Miraco is in data transfer mode, and currently doesn’t work at all over USB, this means you need to have Revoscan 5 installed and you need to transfer the entire project over wifi, just to be able to export the obj or stl.
- What I would like to see: option to share the stl or obj directly from the Miraco.
- Ability to use the Miraco as external drive on a Mac
- The general USB issue as mentioned before fixed (not fixed in 5.4.2).
- Option to use a USB(-C) drive with the miraco to transfer files.
Thanks
Björn
