Does the Range work with the Iphone15 USB-C?
Hello All!
First post here as I haven’t seen an answer through search. Does anyone know if the Range can now be used with the iPhone 15 usb-c connection instead of wifi?
If so, does it still need to be powered separately by the USB power bank or will the single cable suffice?
Thank you!
Not it can’t … just because it uses USB C means nothing … there are other reasons for that … that why for now only via WiFi
Ok :+1:t4: thank you for the reply. I was hoping for a hardline as an alternative to wifi but that will work for now.
Without Apple being involved in it , it simple can’t … you know they don’t allows random devices to be connected without proper licensing what is expensive…
You’re absolutely right. I didn’t think about the licensing aspect. Well I’m glad at least it works! Thanks!
iPad Pro has had USB-C for years and none of the Revopoint scanners will work cabled. As PUTV says, for hard connections a device has to be Mfi certified (unless it’s something dumb like a pen drive or an HDMI converter) which costs $$$. They then have to pay Apple $$$ for every device they sell.
WiFi works just fine though.
