Dfodaro | Revopoint 3D - MetroX | Showcase
Hello heveryone,
I share the first scans made with the new Revopoint3d scanner now on METROX’s on KICKSTARTER
METROX’s on KICKSTARTER 4 scanning modes give you the right tools to optimally capture every aspect of small to medium objects, from flat areas to complex details.
NOTE : All Scans in my showcase were captured using Beta Prototype of MetroX and its Beta Software and not using the final Public Build .
I am dfodaro a professional art conservaton (with 40 years of experience) and use 3D tecnologies in my work on cultural heritage for more than 10 years.
Below are my first scans with MetroX, for now I have been using the Full Field mode which has proven to be very smooth and quick to use
Below is a series of tests and trials that demonstrate how a tool like MetroX can be used, with notable results, even in a different field such as the conservation, preservation and restoration of Cultural Heritage.
Little ancient bronze statuette with dark patina (15 cm high)
Mode: Full Field on turntable
I completed the scanning and below are the various steps and the result
Size in Meshmixer
Ancient wood sculpture (dark surface) (39 cm high)
Also here the scan was easy to perform
Size in Meshmixer
Ancient Small Metal Sculpture of Ganesh (33 mm)
Mode: Auto Turntable
I tried with this tiny sculpture the automatic scanning system, which is a really easy and fast way of use for such a small object (33 mm)
During scanning
Size in Meshmixer
Patinated plaster sculpture model (36 cm long)
Mode: Full Field
Another sculpture (medium size) with rich surface morpholgy (see the final result in Meshlab)
Fusing
Fused
Meshed
Size in Meshmixer
Final result - Meshlab
Final result - RevoScan
Ancient British Imari-style jug (11 cm high)
Another smooth scan with color
Scanning mode: Auto Turntable - color
All automatic scan with only 36 frames with METROX’s on KICKSTARTER
Size in Meshmixer
Scanning: Raw
Ganesh Stone Ring (21 mm long)
A laser scan METROX’s on KICKSTARTER o a little Ganesh Stone Ring
Scanning mode: Parallel Lines
Scanned by placing the object on the turntable (kept moving) and MetroX in hand passing the surface back and forth like the motion of a “fan”.
Raw
Raw - close view
Meshed
3D model in Meshlab
Size in Meshmixer
Fossil Shell (11 cm long)
Another laser scan METROX’s on KICKSTARTER o a Fossil shell
Scanned by placing the object on the turntable (kept moving) and MetroX in hand passing the surface back and forth like the motion of a “fan”, until all become green.
Raw
Size in Meshmixer
“Fantastic head” Terracotta sculpture (26 cm high)
Scanned by placing the sculpture on the turntable (kept moving) and METROX’s on KICKSTARTER in hand passing the surface.
Close up of point cloud in Revoscan
By enlarging the point cloud you can see how “dense” and “clean” it is
Size in Meshmixer
Ancient Chinese Canton-style vase (10 cm high)
All automatic scan with only 72 frames with METROX’s on KICKSTARTER
Summary video
*Raw
Fused
Meshed
Textured
Sixe in Meshmixer
The vase’s fine surface morpholgy in Meshlab
The thin layer of the decoration paint is perfectly recorded by the 3D scan
Fossil Shell
Scanning mode: Cross Lines
Scanned by placing the object on the turntable, kept moving, with some marker block
until all become green. I performed two scans (up side and down side) and then merged them.
Below are the screen shots of all phases.
Scanning
Raw
Meshed
Scanning the other side
Merge
Final model - 0.1 spatial resolution
3D model in Meshlab
second scan with METROX’s on KICKSTARTER
Mode: Parallel Lines
Scanning process: Scan by two sides - Merge the scans - Fusion and Meshing
Scanned by placing the object on the turntable, kept moving, with some marker block to have more references.
Final model in Meshlab
Ancient Dark Shiny Bronze: Nude (36,9 cm long)
Another laser scan METROX’s on KICKSTARTER , today a challenge: a dark bronze
Scanning a bronze sculpture with a dark patina is a challenge for those who need to create a quality 3D model with high detail.
MetroX in the Cross Lines laser scan mode allowed me to carry out the scan and the Marker Block Kit was essential to avoid placing the markers directly on the surface of the sculpture.
Truly amazing result.
The scanning set, in the images below:
the scuplture is all surrounded from many marker blocks.
Scanning (scanning time: 7 minutes)
Raw
Fusion
Fused
Meshing
Meshed
Final result
Meshlab
Size in Meshmixer
Blender (overviews and details)
Ancient Tea-Pot Chinese (XIX century) - metal and sculpted/engraved wood decoration (10 cm high)
Another laser scan accomplished with METROX’s on KICKSTARTER
Scanning a metal-wood tea-pot with a dark patina and shiny metal is a challenge if need to create a quality 3D model with high detail.
MetroX in the Cross Lines laser scan mode allowed me to carry out the scan and the Marker Block Kit was essential to complete the scan.
The tea-pot was scanned from different sides ( teh tea-pot surrounded from many marker blocks) and the 6 scans obtained were merged in Revoscan.
RevoScan
Merge
Merged
Meshing
Meshed
Size in Meshmixer
Meshlab
Vintage opera binoculars - metal and black imitation leather (9,6 cm long)
Black and metal object laser scanning with METROX’s on KICKSTARTER
Scanned (two sides) on tourtable with markers blocks
RevoScan
Alligned
Fused and Meshed
Meshlab
Size in Meshmixer
