Hello, it could be possible to make an improve that allows to delete points before cloud point fusion?
Or it is It is absolutely necessary to keep all of it?
Thanks.
Thanks.
Hi @Angell
You can remove /edit raw scan before firing but that depends of what scanner you use and what mode? Currently laser mode do not have raw edit , Full Field and Single Auto shot do have raw edit
Metro Y Pro - Laser mode. It is not necessary to fusion all points, that takes a lot of time it could be more efficient to delete raw points that not fit the model before cloud.
Hi Angel,
Yes currently there is not yet a way to remove raw data when scanning using laser mode , too much data to be handled but I am sure in the future the Dev. Team will a good way for that feature.
To avoid getting too much noises and additional lose points, avoid to scan surfaces with too high laser settings if not nesesery , especially surfaces that are reflective van generate micro noises and reflections that are captured by the software while scanning , there is lots of stuff to get this under hand , lower the brightness of the laser , use 3D spray or matting sprays .
Yes the problem is that I choose black part mode to scan becase is a plastic black part, over a black table over the turn table black…![]()
That made a lot of raw points.
Is just an example how delete raw points woud be very usefull.
Hi @Angell
If you used laser mode you can’t edit the raw data , the raw data is just visualization , not currently editable under laser mode .
Make sure the object is not direct on the black place / turntable , I use plexy glass and put on it my objects , then set proper the brightness of the laser so it only capture what I need , however if your surface is black and shiny, you can’t do anything about it if you don’t use 3D spray , Raw edit only remove manually parts do not clean noises , you will need to do it after fusing and use the cleaning tools like lose points cleaner and overlapped points to get rid of the noises
For anything else check the great collections of Tutorials in the forum .
thanks for the insight. Would you mind showing a photo of how you actually place a (transparent, I suppose) plexiglass beneath or above the part, please?
Hi @Mr_Wolf
Just place it on the turntable or surface and on top the object .
The “future” is now for other manufacturers and it is NOT a minor problem. Background geometry is unavoidable when scanning sections of larger assemblies and having no ability to exclude redundant data before “fusion” is an issue!!!
Also there is the thing about not being able to export the raw point cloud before fusion. So we have an important missing feature and a block on using our own tool chain.
I would really LOVE to be able to just export the raw data and not have to rely on whatever post processing might or might not happen during the incredibly slow and zero customization options “fusion” step.
Hi @Neb
The RAW scan is nothing else but data from the folder , it is not editable, it is virtual preview in real time so it can’t be exported as it virtually don’t exist as organized cells until it is fused .
You see , fusing is what really create the real RAW scan/point cloud , fusing is nothing else but organizing cells into raw point cloud .
Hi @PUTV
I think you may work on delete raw points (areas) before fusion.
That would save a lot of time.
Hi @Angell
Right now when scanning using Laser mod and removing partial scan areas using the RAW edit will cost more time that fusing the whole original scan , the Dev. Team as always is working to find a better solution.
The frames that laser scanning capture are so small that editing or fusing takes a lot more time compared to structured light technology where the single frame is huge .
One single 360 rotation angle needs 36 frames with full field, the same angle using laser scanning at least 8000 to 20000 depends of details .
That is the reason why the computer have to process things longer and why it take so much time.
26 years ago it took me one month to fully clean and edit a detailed scan , today it is fraction of time in minutes. I can’t complain but as much as you I wish it to be little faster, we need to wait for better solution .
Hi @PUTV
Thanks for your continuous improvement.
Yes, I agree. Plus, the software for cleaning and editing pointclouds 26 years ago was incredibly expensive !! Not free like Revoscan. I remember the Scanning to editing ratio was something like 1:4
