Can anyone tell me can you scan say a black dog with the pop2
You can if you spray it with some dry shampoo
… And if it stays still for quite a while
You need to use dark mode with a higher gain settings but not gonna be easy if the dog moving …
It also depends if the hair are short or long , shorter hair works better
@ivan it depends of the hair type , shiny or not and the amount of sebum they have , fresh washed and dried hair scan better than black hair washed day before .
It’s not much about the dark color , it about the amount of oil they absorbed .
I used white product for hair that make your hair white , but it was wax based so it was invisible to IR also . Wax absorbing IR no matter the color due to high value of IOR . ( Index of refraction)
Always learning a LOT from you PUTV. Thx!
