I put this highly detailed Marvel collectible to the test using a mini turntable + handheld scanning.
What do you think?
Can the Revopoint POP 4 Scan Rocket Raccoon?
| 3D Scanner First Test
What do you think?
Good work @Frikarte3D
Despite the fact that it was done on mobile app , it looks very good.
Yes, I have issues with the Scanner on PC and I think itβs due my computer donβt have USB 3.0 or they are not working fine. More tests to come ![]()
Hi @Frikarte3D
Please use WiFi connection if the USB is not available on your PC . The speed should be the same !
Btw POP4 new firmware was just released , connect to your PC via USB , and update your scanner , you will be able to collect phone photo textures and use them with your scans.
Also remember you can import your phone scans to your PC and process them there at higher quality.
