Now Im really starting to regret my purchase!
First, the POP4 refused to work on any of my current system (Windows wasn’t equipped with the right videocard á ca. 250$, not on my Macbook with 32 Gb memory because that wasn’t the right CPU, and the iPhone software would come later but would be restricted due to logic reasons.)
Leaving me not much choice other then find some fundings to buy at least a system I could use my new scanner, so now I’m out an additional $700 to be able to use the scanner … still only partially I just found out because you people still don’t have the mirror software in order for Tahoe!!!
So to say I’m disappointed is the very least you might call the feelings I have on Revopoints great new scanner!
Hi @Benji
So you know the computer specifications that are needed , if you have good CPU you don’t need additional graphic card at least for Lasers mode because the other modes works fine on my old windows tablet , so what is the Windows system you talking here about ? Specifically the CPU ?
If it is i7 8th Gen you can only use Full Field, if you have i7 13th Gen you are ok for the 3 modes and maybe slow Lasers mode . So definitely graphic card required for laser mode at least 3050-4060
Android app runs only 3 modes , and Revo Mirror require full system to run as it harvest the power of your system and not your phone so neither your Win or MAC will be usable .
To be honest, Revopoint offers one of the best cost/performance ratios among all the brands on my list.
The only area where I feel it falls behind is software development — for example, it still lacks native Apple Silicon (Mac M-series) support, unlike some competitors. That said, requiring an NVIDIA card seems to be pretty much mandatory for any serious laser scanner brand right now.
Bought myself a 2020 MacBook with sufficient specs to run all options, only to find out the Mirror option … not so much. But hee, it works and I can finally start learning 3D scanning! So now I’m a little less sad again with my new toy!
Hi @kkula9999
Revopoint is working not only on the native Apple app but also on a new software supporting ADM graphic cards and not just Nvidia.
I actually don’t even use my Nvidia card as my CPU scans at the same speed anyway when using Laser mode . So beside 3DGS it is not really requirement anymore .but rather a choice.
The Mirror app will be updated soon so you can use it as well , if I remember good middle July .
Looking forward to see your progress !
I’ve been having a lot of frustration with it as well
My PC definitely has the right specs but the scanner only works once from a fresh reboot, if I close RevoScan after the first use it will no longer work, giving me “license not detected” whatever the hell that’s supposed to mean
I can’t get it to work on either of my smartphones, and my laptop just doesn’t have the specs to work with it
I’m mulling over whether I should just cut my losses and sell it or if I should get a laptop that would work with it, because even IF it worked on my PC, I would be tethered 6ft or kneecapped by my limited wireless setup
It’s especially frustrating, because the scanning portion isn’t bad and the POP4 seems to provide the level of detail I was looking for in a scanner, but you can’t win them all I guess
"My PC definitely has the right specs but the scanner only works once from a fresh reboot, if I close RevoScan after the first use it will no longer work, giving me “license not detected” whatever the hell that’s supposed to mean"
This means the scanner is not detected , I will check up with the team regarding this issue
Don’t give up, I now can start learning to use it and it really seems like fun (bought me a M1 MacBook just to get here) … now its just waiting for the know how for me …:smiley:
Hi @cmayk
Make sure you update to the new version of Revo Scan 6.2.3 Win , if you have issues with activation send your POP 4 serial number to customer@revopoint3d.com and request offline activation files , after that you can manually activate it on your computer.
It’s past the middle of July now … still no Mirror app for my Mac?
Hi @Benji
The MAC Tahoe version will be released this week.
They want you to jump threw hoops to get the offline activation files. i am now on day two of waiting for the files. Why not do away with this need as it seems to be frustrating step to everyone. you can’t do the online activation when the scanner is connected wirelessly because you are connected to the scanner and if you connect back to your network the activation prompt goes away. I am ready to return the scanner due to this issue.
Hi @Jcrash77
I answered you to your original thread with this issue.
Got a question, My pop 4 doesn´t work if its connected directly to the 40Gbps port, it doesn’t even let me start the scanning. Then bought a tp-link hub that solve the issue, however the scanner is always disconnecting in less then one minute.
What should I do?!
No, it doesn’t look like that on my systems …
A few weeks later and still the same message about Tahoe support. No new excuses?
Hi @Benji
The Dev. Team is back at work yesterday after week off , that I guess courses the delay in release .
You wrote earlier that the Tahoe support would be available somewhere in the middle of Juli, so my advice is to get your communication with the department straight since the first week of August is well on its way to be history!
But I’m giving up on Revopoint and gonna try to sell it, to at least get some of my money back.
Hi @BenZ1
I don’t have to get anything straight with the communication , it was planned but it failed to pass the beta and need to be reworked.
I can’t control when things are released , but I can share what I know at the moment so please don’t kill the messenger.
If that was up to me I would have it done already , but I don’t have that power.
