Artifacts on edges
Hello, community.
I am getting splash-like artifacts on the edges while scanning with cross and parallel lines.
Here are some examples:
  1. Metal object, matted with spray.
  2. Plastic object (unmatted).
  3. Ideal metal cylindric part (Okay, this one is easy to fix)
Can you please give me some advise?
I have read neibour topics with explanation that it is application problem.
Edited to compy with the forum TOS
Hi @oneeightytwo
First if all you need to scan well all the edges , if you don’t capture the edges it will create artifacts since nothing is there or missing .
Second you need to clean the lose points or overlapped points before meshing , the meshing settings looks like too small but I am not sure what was the fusing settings
It can be fixed but you need to pay more attention while scanning , especially the edges.
