[Android] Revo Scan 6 is Now Online
Hi everyone. Revo Scan 6.0.1 for Android is now available.
Download it at:
Android:Best 3D Scanning Software - Revo Scan 5 and Revo Software
Updates:
Revo Scan 6 - Fully Upgraded
1. Adds new scan templates.
2. Adds timed single-shot capture.
3. Adds support for grouping, sorting, and searching of scan files.
4. Adds support for POP 4 (Supports Wi-Fi connection only).
5. Optimizes point cloud fusion processing speed.
6. Adds new fusion optimizations.
7. Adds marker radius setting.
8. Optimizes mesh processing speed.
9. Optimizes automatic hole filling.
10. Optimizes the UI and interactions.
11. Optimizes the user experience.
Will it be available on Google Play Store ?
The version i downloaded is 5.4.2.
Yes it need couple days to show up on Google Play
The instruction above required download direct from the website to get the latest version at this moment .
Is it planned to support also laser scanning mode on Android app?
Hi @mr_cg no , phones don’t have the power of a PC with Cuda cores so no It will not , for that is Revo Mirror that works on the phone but harvest the power of PC to make scanning with laser mode possible on larger distances .
competitor supports laser scanning mode on Android app and it works like a charm.
I see no reason why laser scanning mode should not be possible on Android with Pop4 scanner.
That would eliminate lots of users phones as for that function you need really good Android phone , not even i7 8th Gen CPU can handle it proper it requires at least i7 13th Gen or GPU with CUDA cores.
I don’t know about competitors but it need to be some king of gimmick , because how even the phone RAM can handle 30K or more of frames the size of 18GB with 8 or less GB . They probably use some hybrid way but it can’t be true Laser scanning on its own as that is technically not possible with a phone processor to archive this level of accuracy.
And then you would wondering , why spend 65K on laser scanner when you can use competitors with your Android phone . That makes no sense .
Revo Mirror allows to harvest the power of your PC to do the things right , or you can switch and use gimmicks , the choice is as always yours .
It’s true that good Android phone would be needed. But most recent Android phones have those. I used laser scanning mode with Samsung S24 and RaptorX many times (only parallel laser was supported, no crossed laser) without any issues and it was extremely useful to have this mobility option. Excuse not valid, if other vendor can provide it also Revopoint should be able to provide it. It’s just a matter of effort and willingness.
That decision is up to the boss and what the company decide to do or not , regardless what I say or want. Revopoint created better solution to it what is Revo Mirror that can do the whole 5 modes at a very large distances in place to limited the users regarding what phone they are using it can afford . Considering the prices of a good phone it is already better to get a laptop . Or it would limit the users dramatically just because of some laser gimmick simulation. Not worth it
You are welcome to contact customer@revopoint3d.com and send your feedback directly .
With my Honor Magic V2, the WiFi it connected to Pop 4, but on the app, the scanner isn’t visible. If I connect directly to the phone it doesn’t start. Suggestions? Thanks
Hi @Carioca
The POP 4 can only be connected via WiFi , you should not use USB cable to connect it to your phone even with mobile cable with power Bank , the support may be added later .
Please send your full phone specifications to customer@revopoint3d.com for technical assistance.
Not all phones will work , my new phone don’t either but my old phone from 2 years ago do , so let the technician check the compatibility for you.
I am not able to get the POP 4 to be recognized on the Pixel 8 Pro. It is able to see and connect to the wifi but unable to show up successfully on the Revo 6.0.1.125 app.
Hi @billybookcase
Please contact customer@revopoint3d.com with exact your phone specification , they will help you out
