Alternative for original black sheet
Hi. I’m Range 1 user and it’s first time to post this forum.
Currently I’m looking for black sheet that possible to be exclude from 3d scan like the one included with original package.
(I threw away the original stupidly)
So does anyone knows alternative sheet and the material in familiar markets like Amazon?
Thank you.
A black plastic trash bag works fine for me🙂
Thank you for informing.
I bought similar cheapest thing these day.
And then I tried to scan the trash bag.
In low exposure case, Range could excluded the bag.(but depended on how facing to the surface and not higher exposure)
Could you scan surface successfully with highest exposure exclude black bag?
You can also buy a black silicone matt , the one people use for hobby to protect table or any black plastic table cloth .
Please use the scanning range settings to prevent objects to be scanned behind your scan … so you don’t need anything else
Just slide the distance until the background vanish in your preview and only model is visible …
If you buy the black plastic cloth make sure it is semi matte and not fully shiny … garbage bags usually are reflective and can interrupt the sensors … so look for textured plastic in place and semi matte.
You have lots of options but I think the scanning range settings will be the best solution for you
Great suggestion :smiley:
In may case, I need to cover background around turntable so need to get black sheet can be excluded from scanning.
It can’t be solved distance slider so far.
I’ll look for black silicone mat like you suggested any home improvement store near my home. (I’ll grab my Range ready to test in the store before puchase)
Thank you!
Disposable black table covers works great for floor covering , I use them sometimes . And usually they are not shiny.
Good luck with the hunt !
