I have a problem with the scanspray that came with my MINI which is the AESUB blue.
Its stated as self-vanishing, but on my hand painted action figure, it leaves on some points on the figure a pale/ white coating…
I tried warm water with dishwashing liquid, but it wont come off. its been some month now having that ruined paintjob on the figure, but now I want to ask, if someone expierend the same and maybe have a solution for me? thanks
Hi @MangoLassi
I did experience issue with AESUB damaging my coins and other materials so I stopped using it and switched to ATTBLIME 3D spray and without issue .
Your paint may had some additive that reacted with the 3D Spray , you never should wash it off , you should put it in area where air circulates the most .
But even after cleaning my coins got damaged anyway as it react like a acid eating up the layer …
It should never happen as that is not the point of 3D vanishing spray .
Anyway write a complain to AESUB as I did , however don’t expect much from them, the reply they gived was stupid like they don’t know what their own product do .
Hi PopUpTheVolume
thanks for your quick answer, that helps. Today I was very confident and used my IPA 99% with a tissue and gently wipe that layer, and a bit of the paint coating, and a bit of paint away… very minimal, but those nasty white spots are gone. I guess you should also try it out with your coins. Maybe IPA 70% is also enough. On my handpainted resin figures I will never use this aesub stuff again. Maybe AESUB transparent … but dont know. I guess scanspray is more ment to be used for the car industry, not for us hobby people. I will look up ATTBLIME also. What product do you from theme?
My coins surface was not dirty , it was destroyed like you put an acid on metal .
It was clean after the spray vanished , but after 2 weeks the reaction happened while stored away .
I am never going to use AESUB again that’s for sure , beside it is too thick and take too much details away .
Comparing AESUB to ATTBLIME is like snowfall to frost .
ABzero which is more sensitive to the material, layer thickness?
And ABP, which is cheap and need to wash away, layer thickness 5,16 µm
Only AB2 & ABP are free of ethanol, which makes them - I guess less aggressive. AB2 has a layer thickness of 3,6µm.
AESUB transparent has a layer thickness of 10-20μm - but its translucent, so the mini could pick up color data which I like…
hmmm… not sure. Do you guys scan painted figures like me? Should I go with ABzero or maybe give AESUB transparent last chance? Or just go with your AB2
I do not scan color with MINI as it is not good to scan colors due to blue laser absorption , my favorite is POP2 for scanning with color but then I don’t need 3D spray .
However ATTBLIME do not completely hide the color still allows you to scan with MINI even if the color is not scan friendly like red or green and yellow .
AESUB transparent may still leave the colors too intense to use with MINI as all it do is removing only the shine from the surface . The colors still absorbing the blue light .
I guess you need to figure out what is best for you in this case , as you know best what you need .
Trying things out by yourself will give you the best answer .
It is not the same situation , AESUB white is permanent 3D scanning spray , AESUB Blue is temporary 2h vanishing spray , however it will affect some surfaces .
I skipped to use it all together .
