3D Connexion Space Mouse Support
Hi @R-RICHALLAND
Not all models are supported at this moment.
You can post your suggestion for your model under Feedback and Suggestions in the forum.
Would you also please add the Space Pilot 3D Connexion. Unfortunately I can only use it to a limited extent
Thank you for your suggestions
Okay, we’ll see how we can support it. Do you have a way to provide a picture of it?
Hello Jane,
thank you for your quick reply. The Space pilot from 3d connexion is an older model. But it still works well. I can use it with Fusion 360 without any problems but unfortunately not with Revo scan 5.6.3 Metrox. The Space Explorer from 3d connexion works great with 5.6.3. Attached you can find some pictures of it.
Many thank you for your efforts
Uploading: IMG_20250213_223633.jpg…
Uploading: IMG_20250213_223610.jpg…
Any serious 3D software would be well advised to support the 3D mouse. I use the Space Mouse Enterprise and the Space Mouse Compact from 3DConnexion for Autodesk Fusion, Blender, and Bambu Studio. All of them support the 3D mouse, and I couldn’t work without it. In Revoscan, most of the time is lost during post-processing, and in this case, rotating the object with the mouse. Besides, the fact that competitor doesn’t yet support it should be a huge incentive to demonstrate how to do it properly.
Very good new. I use 3D Connexion Mouse in Revoscan is so helpfull
How do you uise it in revoscan, my will not work
Just turn it on and it should work jist fine in Revoscan.
However Revoscan MetroX. Last i checked did not have support for it
RevoScanMetroX users said it working just fine in 5.6.5 and better than ever before, including Merge tab .
Maybe depends on the type
Ok just check and yes in 5.6.5 its work.
I know it was not in the older one.
And mine is the small knob only one.
And does not work on the merge tab for me
I use 3dconnexion enterprise on a win10 computer and a 3dconnexion spacemouse compact on a win11 computer. Both work with revoscan 5 and revoscan5 X, but unfortunately neither program works in the merge tab, programs and driver are uptodate.
That is mostly when it is needed, thank you , I will forward it to the team tonight.
Just want to report that my SpaceMouse Wirless does not work on Revo Scan 5 MetroX. Disappointing because it would be great in this software. Is this support coming? I’ve tried disconnecting and reconnecting and power-cycling the mouse. No luck.
Hi @freshmint
Can you explain why it don’t works ? You mean it works just fine until you open Revo MetroX and then it disconnect completely ?
Or it just don’t works ( functions ) at all ?
Did you tried Revo Metro the new software to use with your MetroX scanner?
Can you share your experiences with that ?
And yes R&D team will look into it but rather in Revo Metro since the other software is about to be archived soon .
My 3DCONNEXION space mouse wireless, https://3dconnexion.com/us/product/spacemouse-wireless/
Works fine in windows 11 x64 using Fusion 360 - but it does not respond at all in the latest version of Revo Scan 5 MetroX.
I am using latest drivers from 3d connexion and latest version of Scan 5 MetroX
Hi @freshmint
Revo Scan MetroX will be no more updated since Revo Metro is the new software that will handle MetroX scanner and is already available .
The R&D team got informed about the issue with the Spacemouse , I don’t think this one was supported yet . They are looking into it
Mine is the wired version and works great in latest version. It didn’t in the previous though and I think it is because I had revoscan metrox installed before getting the space mouse. I then uninstalled revoscan and deleted folders, then installed it again and the mouse worked. So try uninstalling revoscan and looking for the extra folders and then reinstall it.
I have an older small wireless spacemouse and can report it works great in latest version of Revo Metro on windows.
