I’ve been using my iphone to scan a car but it is maxed out at 2500 frames. Is this really a case of not enough memory (my phone had more than enough) or is this a limit that Revopoint have set for it??
I need to go as high as 15000 frames to get a good size scan.
each 2500 frames , please fuse it and continue scanning , your phone will never be able to process or fuse 15000 frames from one session . That are 25 full body scans at once and no phone can process that in one run . It would be even an issue on a PC with 64GB to perform that task as the files will be enormous .
Remember that by each fusion after scanning 2500 frames , your RAM will decline slightly so not sure you will ever reach your goal .
