[Windows&Mac] Revo ScanMetroX V5.6.5
Hi everyone. Revo Scan 5.6.5 MetroX for Windows and macOS are now available on the official website.
Download it at: Best 3D Scanning Software-Revo Scan 5
Updates:
  1. Improves marker tracking stability.
  2. Adds quick access to Revo Design on Windows systems.
  3. Adds GPU acceleration support for Windows: RTX 2060/2070/2080 Super, RTX 3500 ADA, RTX 5070/5070 Ti/5080/5090, RTX A6000/A5000/A4500/A3000.
  4. Updates the user manual.
  5. Fixes some bugs.
  6. Optimizes the user experience.
It’s a pity my 2080 ti is not supported
Yay! I can use GPU acceleration on my new laptop.
dissapointing that I still cant. Nvidia Quadro RTX3000 / RTX5000 on two laptops…
Even that I was promised that they will add this
Quadro RTX3000 will not make it , but Quadro RTX5000 should as it is slightly faster than the minimum requirement for the software.
I will leave a note tonight to the team.
Tomorrow morning we will evaluate this issue with the team.
It should be included.
I am on it ,don’t worry
i too have one laptop with RTX 2060 and nother with RTX 4050 Laptop and neither are supported via GPU. an that be added to the list?
RTX4050 works already with the old version from 30x to 40x series
Only RevoScan MetroX
RTX 2060 was added to the new upgrade today of RevoScanMetroX
Regular version of RevoScan don’t support GPU acceleration, only RevoScanMetroX and only using Laser mode while scanning and nothing else.
If your frame rate speed is 57-60 while scanning with laser mode then the GPU acceleration is working .
If not , update your driver and setup GPU acceleration under the software settings.
At this moment both of your cards are supported already with 5.6.5 version of RevoScan MetroX when using GPU acceleration and laser mode.
As mentioned in another topic, even Quadro RTX3000 Mobile is quite better than GeForce RTX 3050 which is mentioned in minimum requirements. But Even the Quadro RTX 5000 Mobile is not supported
https://technical.city/pl/video/Quadro-RTX-3000-mobile-vs-GeForce-RTX-3050-mobile
I already answered you in the other topic on this matter.
my intel i7 12th gen 12800h and 32Gb ram was working fine with 5.6.4. now it is just lagging and can’t see markers (almost like the marker tracking is not prioritized. i’m on CPU only since T600 gpu not supported. same problem on another PC with i7 9850h that was scannin poorly but doable. is now unable to use. so basicly CPU scanning is broken for me
The minimum is Intel i7 10th Gen 10700 so you should be able to use it normally yet it will be not the optimal results.
Lagging in what mode ? laser ?
Check your graphic card to make sure it is set on performance or change the viewport preview thickness of the lines to lower before starting scanning.
Avoid too many markers that are too close , at least 3 cm distance if on flat surface.
I can still use Full Field and Auto mode on my win tablet with i7 8th gen without issues for scanning .
The Markers works differently in laser mode than Full Field , since only 800K points are activated at once compared to 7 millions in Full Field that have bigger range of view and markers detection at once.
P.S without markers the laser will not fire or scan anything , it is the priority to even start
I suggest your check your calibration results as bad calibration starts with markers being not detected.
Anyway thanks for the feedback, I will forward it to the team.
yes. i have about 3-4 cm between the markers. on 5.6.4 the “frames” per second is about the same as 5.6.5 but the markers are not tracking. i must keep the scanner 90 degree perpendicular to the turntable or else it is not detected and the “point cloud” preview is like 1-2 frames per second (not the same as frames per second capture) when scanning in 5.6.4 i get about the same frames per secound 43 fps as in 5.6.5 but now the Markers are detected at at least 45 degree angle to the turntable and is 25-30 frames per second updating the point cloud preview"
it is in laser mode cross and parallel mode
Ok I am detecting lately some error with markers if the scanner is not at the 45 degrees , it may be not your system but the software bug .
I noticed it lately and will discuss tonight this issue with the team.
good day, will the RTX A500 also be supported, it’s on the border of the recommended performance, is it possible that you will add it? Thank you
Could you capture a video so we can clearly understand your issue?
RTX A5000 is already supported in the latest version 5.6.5
Why is there no support for RTX A4000?
Forgot to add to the list? It is almost no different from RTX A4500
I have RTX A4000 and I can’t enable GPU acceleration (
Probably by mistake , I already reported yesterday to the team.
