After fusing, overlap detection is stuck on 0.01 with no ability to change it. I don’t think it’s just a visual bug since it actually detects nothing. If you perform isolation detection, overlap detection will return to a normal value (there may be other cases where it becomes unstuck, but this always works).
Also, overlap detection doesn’t calculate a new value every time you use it anymore, so I’m not sure that doing multiple overlap detection passes until none are detected is working the way it used to.
Is it just me doing something wrong or the import from phone function really disappeared from the home screen? if it was moved somewhere else, where do I find it?
