I’m still getting familiar with my newly arrived MetroX and found that as long as power cable plugged in, the fan on MertoX keeping running. So I’m not sure whether I should wait for the fan to stop then unplug the cable form MetroX. I haven’t found any related answer on manual so now I just unplug the cable after finishing my scan.
Just unplug the cable from MetroX after closing the Revo Scan first . Never before closing the software.
Then after that the AC adapter from the outlet and that is .
Yes, @PUTV’s steps are correct. You can also follow the sequence recommended by the dev team:
Unplug the USB cable from the computer.
Power off the scanner.
Unplug the scanner’s cable.
By following this order, it is possible to minimize signal interference caused by interface shaking during the process of plugging and unplugging the data cable, thereby reducing the likelihood of issues affecting the computer’s USB port.
This would highly surprise me. USB is by design hot-pluggable. If the device breaks due to wrong connection or disconnection order, that would be a warranty case. Pretty sure Revopoint knows this and designed the scanner accordingly.
The point is that if you disconnect the actual AC power before disconnecting connecting the Software the computer USB will try to reconnect and because there is not enough power in s USB port it may side issues to USB port
On that I agree with you. It might confuse the software and/or the OS and/or the firmware, leaving you at worst in the situation where you have to reboot the system. Should not happen, if well designed, but might be the case.
But honestly haven’t really cared about what order I plugged and unplugged, and the scanner could always connect nicely.
I tried it. And it works like a charm. Revopoint engineers did their job well in that regard. Plug USB in, but no power → of course, the SW complains about disconnected scanner. Plug in the power cable and hit the “X” so it tries again → Connected. Unplug the power → immediately disconnected. Re-plug the power, hit “X” to try again → Connected.
This is a USB device. Just plug it in when you use it and plug it out when you stop using it
