Test Toilet Paper on MetroX
Parallel laser mode 0.2 scan resolution, 0.07 mesh construct
You mean by 0.2 scan resolution you fused it at 0.2 and meshed at 0.07 ?
How do you get meshing at 0.07 when the max is 0.15 ?
Yes, that’s right. 0.2 is the minimum resolution for laser scanning. 0.15 is the minimum distance when optimizing the point cloud. And when building a mesh, it gives you a choice of 0.07
The 0.2 is not a resolution it is only for the viewport how small you see preview of the frames while scanning, the settings do not affect the final scanning resolution.
Just for visual purpose .
Fusing is 0.15 mm
And meshing at level 8 maximum ( depends of the volume )
Anyway, I really like the result that turned out :slight_smile:
That’s wonderful !
how would you clean up the marker block?
scan few times by putting the block to different location, cleanup and merge?
In general, markers are poorly removed at this stage. This scan was for the purpose of a test. Don’t get me wrong, but Revo Scan is currently at about the same level as CrealityScan from August last year. So let’s wish the development team a successful development!
It has fine patterns embossed on it. Less than 0.5mm into the paper. A fun test to see how well the scanner picks up fine detail.
We once scanned Zewa Three-Ply Toilet Paper with a Mini 2, we used up about 90GB of RAM, but the scan was incredible :smiley:
