[Solved] RevoStudio deprecated? Now what?
I fired up my Pop3 and did my first scan, then went to download the editing software - to find it has been deprecated.
I assume I can still use it, at least for a while, but what is the recommended tool now to convert the scan into a 3D model?
Hi @EdwinWiseOne ,
Now we combined the features of Revo Scan and Revo Studio into the Revo scan. You can edit the models directly in the Revo Scan 5.
Here is the link: Best 3D Scanning Software - Revo Scan 5
Hi @EdwinWiseOne
you should not use the old Revo Scan 4 with POP 3 , it is outdated and it do not support POP 3 optimal .
You can still use Revo Studio but it is slow compared to the new Revo Scan 5 that have all new Tolls you need .
As Cassie mentioned , download the new RS5 from the download page , check also the Tutorial section in the forum for quick guide .
Revo Scan 5 offers also informative guide under each tool to better understand the process .
After you scan your object, you need to fuse it , after fusion you need to clean the overlapped points and lose point , cut the parts you don;t want in your scan , then after the point cloud is ready and clean you can process to mesh it and texture it .
Revo Scan 5 Best 3D Scanning Software - Revo Scan 5
Okay, so I didn’t see that you can edit in the scan software – the name is confusing and I assumed it was going to be about the same as on my phone (which doesn’t seem to have editing). Thanks for the replies.
Thank you for the update. Just to clarify, the editing feature is currently only available on the PC version of the Revo Scan.
