Scan42 project for help scanning
My dear friends, good evening!
Here is my new project #Scan42
It allows you to raise or lower the #scanner3d at the desired speed relative to the rotating table.
I adapted a part for the mini table (10cm base) and one for the dual axis table (20cm base)
I still have to refine some settings but once done I will make everything available for free on the various platforms.
There will be a pdf tutorial to have the list of equipment, assembly and configuration of the controller.
I hope this can help as many people as possible :wink:
Long life and prosperity, may the force of print be with you!
Well done Julien , thanks for sharing!
My dear friends, good morning!
Here is my Scan42 project, it allows to have a motorized Z axis in order to facilitate the scanning of an object on a rotating table.
All the explanations can be found here: https://docs.google.com/…/1b4V62LRrMEDR1ZmdX9c5…/edit…
And the files can be found here:
Printables: http://www.printables.com/…/1043263-scan42-scanner…
Makerworld: makerworld.com/en/models/711799
cults3D: cults3d.com/fr/modèle-3d/divers/scan42-scanner-mount-automation
The project and the manual will be updated as needed. But here is what has already started the project. I am open to any thoughts that can make the project evolve for the community.
What a pity that this thread is a bit hidden with all the news related to the MetroX. There is a lot of 1st quality stuff here.
Hi Roberto I pinned it for a while
