I have been trying to use Revoscan 5 to import ply files and merge them together. When I do, they come in as meshed and are not available in th merge option.
Revostudio 3 allowed this and worked great. I no longer have a copy of revostudio 4 so I cannot try it there…
Is there some reason why V5 converts or sees ply files as meshed?
It is impossible , nothing is converted to mesh automatic by import .
Check your files , ply is not only reserved to point cloud , it can be also exported as .ply mesh so check what kind of files you exported .
What RevoScan 3 ? There is not Revoscan 3 .
Old program like Revo Studio converted automatic meshes to point cloud by import, Revo Scan 5 don’t do that .
If you import a mesh, it will be a mesh and vice versa.
The files you importing to Revo Scan 5 are not point cloud files but simply meshes .
Ply can be a point cloud and can be a mesh , so check what kind of files you exported from the program , because from what you are saying , you exported a mesh.ply and not a pointcloud.ply
And once again RevoScan5 do not convert any files on import automatic .
You are importing meshes not point clouds to RevoScan5 , let set this as a fact . This is not the proper way if you want to merge point clouds you have to import pointcloud . You make it the wrong way . This not matters how Revo Studio works , we talking about RevoScan5 and how to do it proper . So if you want to use it follow the advice .
Maybe in the future additional option to convert mesh to pointcloud ( sampling points ) will be added , but for now you need to follow the proper workflow .
Because RevoStudio sampling meshes by import converting it into point cloud …RevoScan5 don’t convert scans or models by import , how hard it is to understand?
