This tutorial video will guide you through the entire process of using the photogrammetric capture function on MIRACO Plus.
Hello, I have scanned a car body today with Miraco Plus an the PMK.
Aside from the fact that I have not removed the scale bars before scanning (which led to some issues) the scan generally worked OK.
I still had issues with lost tracking but manageable.
Biggest issue I have is the surface of the scan is very uneven and I got holes where the markers are place… so the scan surface looks not good.
Any idea how to improve this? Thanks Robert
Can you tell me if it is possible to expand the amount of RAM and connect a Power bank?
You can’t expand the RAM , it is final
You can use power bank as well , get at least 50000mAh PD 30W , will give you enough power for full session , remember MIRACO is power hungry , you can read the power needed under the device .
I use this
