Revopoint inspire 2
Hello i need some help.
I have a laptop Asus tuf gamming f16 with 1000gb disk, 32 gb RAM and a grafic card 6 gb.
When I started the program after installation, it checked the system and said it was excellent. Now, after a few attempts, my laptop is very slow. What could be the problem?
Not enough information.
How is your laptop slow? Is it while scanning? Which scanning mode? Processing the scan data?
Which grahpic card do you have? Are the drivers up to date?
My laptop is asus tuf gamming f16, 32gb ram aa grafic card nvidia rtx 4050 6gb.
Wen i start the scanner wiht parallels line starts to stop the scanning Frize the program.
You can try out the newest version (V5.8.6), for me, so far, not a single crash. (Only tested around 2 hours so far tho)
check your laptop temps in a program called Coretemp. my XPS 9720 had a faulty Vapor chamber cooler and could not cool the laptop to standard spesification, so the CPU throttled and the GPU aswell, i could only scan for maybe 20 secounds. also check that you are running the pc at maximum speed and plugged in. right click the battery icon and choose “settings for power and sleep mode”
i changed my vapor chamber and everything went back to normal and the fans where spinning much less at daily tasks
