Content removed by author (MRNC).
Out of curiosity, what’s the smallest point distance you can set for fusion? Specs say “up to .05mm” but I finally got to try it out today and the minimum is .15mm like the MetroX.
0.15 mm , the accuracy is actually 0.02mm
But the resolution is 0.15 mm , anything lower will not make anything better , being there for months testing out the best settings and 0.15 mm delivered the best results and quality , remember resolution and accuracy 2 different things.
Trackit laser mode is as good as MetroX Auto mode … so the numbers means nothing .
