Possible Merge Bug after Point Cloud Fusion?
After merging multiple point clouds to create a complete mesh, I noticed that a hole appeared on the opposite side of the model. This issue only became visible after the fusion process was completed.
Could you please confirm if this could be related to a merge bug, or if there might be another reason for this to occur?
Hi @SphaeroX
Thank you for your feedback. Our dev team is investigating this issue.
Thank you, here on Reddit someone has the same problem: Reddit - Dive into anything
Still present
Before Merge:
After Merge:
I am also experiencing a similar merge bug - (possibly the same?)
[Reddit - Dive into anything]
I would recommend that you follow the rules for scanning thin-walled parts. The scanning resolution should be 3-4 times less than the wall thickness.
If I do it with CloudCompare I won’t have any problems?
I don’t use it, I can’t say anything about it. The only thing I can kind of recommend is that a free product will never be comparable in level to the one that has been invested in the development.
Open Source*
I’m not trying to persuade anyone at all. If you like, use it
the bug is still there:
