Bone Lady here again with another question. The couple of scans I’ve done on the bones end up with over 1M polygons. There appear to be 2 places in the processing workflow to Simplify, after Fusion or after Meshing. What is the best protocol?
What is a good final polygon count to retain the details I need to keep in the bones? and yet not have huge file sizes?
Use only Simplify after Meshing , then you need to Texture your scan after again .
You need to see it yourself , no way to tell you exactly the size as it depends of an object , you can always undo if you find the details are washed off .
I would recommend for your bones around 50% Simplify, so around 500K per scan , it should keep the details just fine .
