I have been using the POP1 for awhile now and generally it preforms very well.
However, when I have tried to scan small tabletop miniatures, 28mm variety, the pop1 fails to recognise various arms,legs and weapons.
The IR camera sees them but once scanning starts there absent.
The features are at least 2.5-3mm in diameter.
If I add some paper, crumbled up, between these items, then they do get scanned properly but the cleanup is much more intense.
I would have expected the pop1 to scan any feature that is greater than 0.3mm in size. However, it appears there is a minimum feature size that is separate from the detail size.
Any thoughts or workarounds?
Thank you
