POP 4's Key "M"
Hi all, sorry for writing but I can’t find an answer to my question in the manual or somewhere else: as far as I understood, the key M in the pop 4 should be able to change “some” features during the scanning without having to go to the Revo Scan Interface. Particullarly during the laser scanning it should be supposed to “swap” from multi line to single line, am I correct? The problem is that mine doesn’t do so, apparently nothing happens if I press it…couls someone tell me if I’m wrong?
Thanks
Andrea
You are most likely doing it incorrectly.
The M button is for the menu. It brings up the menu and allows you to use the +/- and play button to cycle throught and set what the +/- buttons do.
By default i believe it is set to zoom.
You will have to press the M button, use the +/- buttins and cycle to laser mode. Press the play button to comfirm. Now when you press the +/- it will cycle between the laser modes
Hi, I don’t think I fully got the point…should it open the menu on Revo Scan? Are you sure?
Yes 100%.
M Stands for Menu. It brings up the menum its been the same on all the scanners with the M button.
Ok, now I’m at office and I can’t give it a try, so what I should expect is to press the button and see the menu opening on Revo Scan, right? mmmmh…not that useful I think…ooook, thanks
Yep it brings up the menu and allows you to set what the +/- buttons do.
Here is a short video
WOW, thanks!!! ok ok, it makes sense then! Originally I thought it opens the default Revo Scan menu and that’s why I said that it was not useful!!
Great, thanks a lot!!
I treid, the menu appears but when I press the “play” button while the scanning is ongoing nothing happens
Play button only confirms your selection.
You use the + or - buttons
yes, I did it, I pressed M them + until I reached the voice menu for changing the scanning mode, then pressed play and nothing happened…same story with all the other menu voices…
After you press play, that confirms what the plus/minus buttons do.
The menu will disappear. Then you press the plus or minus button to make your adjustments
