Password WIFI desnt accept symbols
I cannot write symbols in the password. Scanner: Range. SW: Revopoint 5.0.2
Maybe because you used Symbols under SSID ? Just guessing…
You need to connect the scanner via USB to change the settings .
No. If i dont write symbols in the SSID, im not able to put symbols in the password either. It is connected via USB. (I cannot connect the scanner to my wifi because the password has symbols…)
The SSID shown in your image has illegal characters for a SSID. I believe + ] / " tab and trailing spaces are illegal.
That what I mean… thanks
ok. dont worry i can use Revo Scan 4 to configure the wifi settings, this versions works fine
I used just one special character in the SSID, but despite that the text under the password states that I can use ‘numbers, letters, or symbols in any combination’, it won’t let me; typing a special character/symbol just doesn’t put it in the text field.
Using Revoscan 5.0.7.320, Revopoint Mini (firmware v2.9.41.20221207)
Please don’t tell me I can enter ‘numbers, letters, or symbols in any combination’ while it doesn’t work, and please fix this!
Use RevoScan 4 for SSID and WiFi password change. v5 doesnt allow special chars like * and this is very weird.
@Revopoint-Cassie @Revopoint3D-Gena
This is a effective bug, even tho the info box states you can have (numbers, letters, or symbols in any combination) the password box does not allow you to add any other symbols then the ones below so no $ or # signs allowed for example
Only accepted Symbols in the password Box:
Hi @DaniCabra
Sorry I overlooked this post. I’ll get back to the dev team about this issue and look for a solution.
Hello,
(sorry for my bad english, I’m french…)
I can’t connect RANGE 2 to my local wifi because I have some specials chars in my password, not accepted by the application:
My wifi password work with all my other system…
Chars accepted: : ; , . ?
Chars not accepted (some in my password) : ~#{[|`^@]}=)àç_è-(é&²*ùµ%?/§€
Hello, we will provide feedback on this issue.
Any solution here? Issue still seems not to be fixed. And i don’t find a Revopoint 4 Version for download. Either an older version or a fix would be nice please.
Hi @Tobitulpe
There is no Revopoint 4 , Revo Scan 4 was working only with very first scanners and is not more available or functional with new firmwares and scanners
I will tag in @Revopoint-Gloria
To find more about that password issues with special signs .
This is still a problem in Revoscan 5.5.4 - how does a simple and seemingly well known bug like this persist for two years?
Hi @ChrisRimmer Revopoint abandoned passwords for their scanner network already , since the network don’t provide any Internet and nobody can really access it
If you talking about the SSID , I will forward it and see what I can get back from the team..
It is not really a bug , it was just design this way .
Hi PUTV, I’m talking about the password field in client mode, to connect the scanner to my wireless network. The password for my workshop’s wireless network has special characters in it, so to connect my Range 2 to it in client mode I have to be able to enter those special characters.
Cheers
Hi Chris ,
I tough it was for the client network mode .
I sent note to the team but please contact customer@revopoint3d.com
It will help the case if you do
