New Miraco update 2.6.35.20241016
A few days ago a new update 2.6.35.20241016 was released on Miraco. My Miraco Pro did not want to transfer files via WIFI to Revoscan after the update. Forgetting and re-selecting the same WIFI network on the Miraco helped. Everything has been working since then.
Is this update for all Miraco? Also Plus?
For me no update is available.
Miraco Plus 2.6.19.20240904
Is there also a changelog available?
I only have the Miraco Pro, so I don’t know if the update is also for the Plus.
Thanks for the Log.
First entry mentions MPlus
Maybe IT will BE available later for plus
There is still a small error. On the Miraco Pro, which does not have photogrammetric functions, there is also a photogrammetric tab in the selection of saved global mark files, which should only be on the PLUS version.
My Miraco Plus won’t update either…
This is not an update for MIRACO and MIRSCO PRO , the hardware don’t support the features and I can’t download it either and there are no updates available at this moment for any MIRACO devices
It was an error
You should not have update your device with this firmware .
Your hardware don’t support the new features .
It was an error on the server .
After turning on Miraca Pro, I received a notification that I have a new update. Why shouldn’t I download the update when Revopoint itself notifies me? Additionally, there are no features that Miraco Pro does not support. There is no photogrammetry, only global markers. There is a bug that there is also photogrammetry in the global markers file selection, but only in the file selection. Everything else Miraco Pro supports including digital zoom and global brands. Otherwise, the firmware runs perfectly, including global brands, and it seems to me that it does not have so much grit in the near s high mode. I can do Fusion-detail on the coin .to 0.1mm instead of 0.2 and it is grain free. The best update for me. If I receive an update notification on my Miraco that is not for my Miraco, it is not my fault. If customers are not supposed to download something that is automatically offered to them, Revopoint should inform the officials about it.
Of course it is not your fault and nobody blame you for nothing
Since the firmware was not created originally for your device there are no bugs to consider
A future update will fix that
I understand that I was probably offered this by mistake and installed some beta update for it that will be common to both Miraco Pro and Miraco Plus in the future, only the Plus feature on other Miracos will be suppressed. But since it has a digital ZOOM instead of an analog one, even in the description it is divided that the photogrammetry function is only for Plus and the others for everyone, so I think it is for Miraco Pro, it’s just a beta.
Are there any other Miraco Pro users who have installed this update?
That this update is not for Miraco Pro is the information directly from Revopoint developers?
Thank you.
Hi Marian,
We apologize for our mistake. Regarding this update, we opened a 2-hour OTA push, and you should have been one of the recipients. However, we have identified some minor issues, so we have recalled this update. Once we resolve these minor issues, we will push the update to users again. You can then check for available updates and install it. If there are no updates available, please contact us.
Both this update and future updates are compatible with the MIRACO series, including MIRACO, MIRACO Pro, and MIRACO Plus. Certain specific features exclusive to the MIRACO Plus may not be usable on the MIRACO and MIRACO Pro models.
So your MIRACO Pro shouldn’t have the photogrammetric functions. Could you please send a screenshot showing the photogrammetric functions appearing on your device to help us better understand where the issue might be? Also, please provide us with your serial number. Thank you!
I have no problem. The update works better than the previous one. There is no photogrammetry feature on my Miraco, which is fine, but the photogrammetry option is offered when selecting the global marker file in the image below. It’s just a little thing. Otherwise I want to keep the firmware, it’s great. I am glad that Revopoint will update Miraco Pro and Miraco Plus together. Thank you.
I thought the photogrammetry was under Scanning settings , in this case it is ok .
The log screenshot was just confusing .
I know version updates not pushed all devices at same time but my Miraco Pro stuck at
App 1.1.0.239
System 2.5.34.20240809
Isnt it weird ?
Nothing is weird, I still have the same OTA as you do , the new update will be released as soon as the little bug is fixed .
